Temperature measurement
Discussion in 'The Projects Forum' started by Konstabel, Feb 17, 2008.
  1. Konstabel
    Thread Starter Active Member
    Jan 31, 2008
    52
    I need to measure the temperature of a tub of water. What would be the best/easiest way to do this. Thermocouple or thermistor circuit? I would like to be able to dunk the sensor in the water.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you use a LM34 or 35, you get an output that is already scaled in engineering units. What is going to be reading/displaying the temperature?
  3. Konstabel
    Jan 31, 2008
    52
    I'll be using the A/D of an AVR and displaying the output on 7-segment displays.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The LM34 gives output in Farenheit, the LM35 in Centigrade.
    There are other options, as well:
    LM134/234/334 - adjustable current source & temp sensor
    LM135/235/335 - precision temp sensor in °K
    LM56 - dual thermostat; in case you want to have fixed triggers at certain temps.
  5. Carbon-based
    Apr 28, 2008
    How would you arrange the LM35 to read a value under water?
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Dip it or wrap it in plastic would do it, you can get insulative dips pretty inexpensively at the hardware store, think rubber based coating.
