My question is which direction should I go to build a temperature control unit which will accept two input sensors and compare the difference between the two and turn on a fan when the difference is greater then what I have programed into the unit. The key is I don't want the unit to care what the temperatures are, just the difference of the temperatures.
As an example one room is 68 degrees F and the other is 76 degrees F so the fan would turn on if I have programed the unit to a 8 degree difference.
I thank you for your help.
JG
JG
