temperature controlled fan speed
Discussion in 'The Projects Forum' started by markosillypig, Aug 21, 2013.
  1. markosillypig
    Thread Starter Active Member
    Jul 21, 2008
    184
    hi every one
    my quest this month is to find a circuit for my winter heat exchanger.
    basically i want the fan to spin slowley as the heat gets hotter i want the fan to spin faster as to cool it down quicker to a set temperature so the hotter it gets the faster it spins
    so i'm looking for a circuit or a link so please help if you can the fan is 12v 80 watts
    http://www.ebay.co.uk/itm/UNIVERSAL...arts_Vehicles_CarParts_SM&hash=item35cad4abed
    thanks for any help
    marko
  2. wayneh
    Sep 9, 2010
    12,405
    3,255
    I'd use LM35 to sense temperature, a voltage-to-duty cycle PWM control, and a MOSFET switch to take the PWM signal and control the fan(s). There are tons of examples all over the 'net since this is the same need that computer fans have - speed in proportion to temperature. A lot of those circuits, though, are not PWM. I'd focus on the ones that are.
  3. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    You could check out one of the $5-$10 PWM controllers on ebay and hook up a thermocouple to the analogue input, you may have to add a little bit of interfacing between T.C. & input.
    Max.
  4. markosillypig
    Jul 21, 2008
    184
    any links or schematics would help thanks
  5. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    One for a start, ebay 271214914630
    Just Google The LM35 data sheet.
    Max.
  6. trader007
    Feb 27, 2010
    222
    19
    i just bought one for dimming an led light strip. they work well, however for lights there is a small 'dead' spot on the low side before it comes back at all the way dim, but its no big deal.
