Temperature Control System
Discussion in 'The Projects Forum' started by lijoostenk, Mar 30, 2014.
  1. lijoostenk
    Jan 25, 2013
    12
    I have designed a temperature control unit with a Proportional Integral (PI) Controller and I intend to use ziegler nichols method of PI tuning. But for that I need to measure the time period of fast oscillations in the temperature output.
    Sensors, which give an output voltage corresponding to temperature, have time constants in the range of seconds which makes it unsuitable for measuring such fast oscillations. Please suggest ways of measuring fast oscillations in the temperature output.
  2. crutschow
    Mar 14, 2008
    13,505
    3,376
    There should be no oscillations from the PI controller faster than the response time of the temperature sensor. If so, then there is a problem with the controller.
    lijoostenk likes this.
  3. Lourens
    Jul 16, 2012
    14
    Try to use the reaction curve method to determine dead time and process time constant. This way you need not get your process to oscillate.
