Temperature Control System (THANKS IN ADVANCE =)
Discussion in 'The Projects Forum' started by Adanovinivici, Feb 26, 2015.
  1. Adanovinivici
    Sep 5, 2014
    58
    Hello All,
    I'm currently designing a temperature control system for a bioreactor chamber and I'm heating the chamber using conductive glass. I'm not sure if I should use a thermocouple or another device that would be more effective. Whatever, temperature sensor, I use, it has to be submerged in water. Furthermore, I'm trying to figure out what circuit I should use and would appreciate some advice.
    Best,
    Vinividivici
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Since your sensor is in water, can we assume that the temperature being sensed is <100degC? If so, thermocouples are not the best sensors for that temperature range. I would look at Pt sensors (if great accuracy is needed) or even just a lowly Thermistor.
  3. Dodgydave
    Jun 22, 2012
    5,143
    768
    The temperature will decide what sensor to use , over 100C pt sensor, thermocouple,under 100C Lm35, thermistor.
  4. Adanovinivici
    Sep 5, 2014
    58
    Thank you. I appreciate the answer.
  5. Adanovinivici
    Sep 5, 2014
    58
    Thanks for the advice.
