Hi all members,
I am new to this forum and basically not an engineering student. Well, I'm a life science student, but I dare myself to create a simple device for heat or cold therapy for rheumatoid arthritis. The range of temperature is from 10 to 50' Celcius.
I want to heat or cool a pad (filled with water) by connecting it to parallely connected 6 peltier devices via heatsink (it will consume a lot of current for sure). I use thermocouple K as the sensor to feedback the temperature. The general idea is, if the user set the temperature below 25' Celcius (assumed as room temperature), then the current supplies the peltier will be reversed. But I really don't have any idea about the control system. One of my friend suggested me to use Autonics TC4S as the temperature controller, because it is relatively cheap and easy to get here.
Is it enough if I control it by using only TC4S? I have searched throghout forums, and some people mentioned about H-bridge module, LM18200, AD595, etc. Do I really need all of them? And what about the required power supply?
http://www.national.com/ds/LM/LMD18200.pdf
http://www.analog.com/static/imported-files/data_sheets/AD594_595.pdf
I desperately need your help, since the deadline is so close. THANK YOU SO MUCH FOR ANY HELP!! DD
Kind regards,
Yugiha
Kind regards,
Yugiha
