I need help with an electric smoker that I have been making. I'm still working on the prototype with a garbage can, and it is working good. The problem that I was having is the heat source is an electric heat plate, and I could set the heat control and get 200deg to hold for a few hours then it would drop to maybe 150deg then jump to 214, it was all over the place. I am looking for 250deg. So I took it apart and looked for some type of over load breaker or high limit switch but didn't see anything. I took the Temperature control and disconnected it and ran power straight to the heating coil. That worked better but I got to 300+ deg. I looked to get a dimmer switch but a 1000w dimmer is $40.
Is there a way to build a dimmer switch that would be less? I'm looking to 1000w at 120v. I have looked into using controls from and electric stove but I would need to go with 220v. Witch is doable but I would rather keep it 120v.
Once I get this to work this is where I would like to go with version 2.
A Temperature control that would work like an oven, set 250 deg and forget about it for 12 hours. Ideally I would use more smaller heating elements like a 600w that would make the smoke and the base heat, then a 2-200w or 400w element that would hold the set temperature.
How could I do this on a budget? I know I can but something but it is way to expensive since I am out of work now. Like always I have the time but not the money.
Thanks, This forum has always come through for me.
