Hello All,
I'm working on a temperature control circuit with altium designer and there are some components I can't find. These components include an LM35 temperature sensor and a TL431 Shunt regulator. I found the package on the Altium website, but it may take a while to get my account up and running due to permission issues. Is ther an alternate solution? I took a look at the datasheets below and tried to copy the function block diagram, but I didn't know how to reproduce the E and 10E (pnp) transistors, but couldn't figure it out. Also the current of the current source wasn't mentioned. In addition, I'm not sure about A1 (if its an Op-Amp or not), but it looks like it compares base voltage from a BJT differential amplifier to signify the difference between input (temperature) and output voltage.
Also, is there any way to program in Altium Designer? Where would I start?
Thanks a Ton,
Adanovinivici
Thanks a Ton,
Adanovinivici
