Temperature coefficient of resistance
Discussion in 'Homework Help' started by Donnybri, Oct 3, 2009.
  1. Donnybri
    Oct 3, 2009
    Using the above equation, I need to find the maximum workable temperature (t2) of a circuit which contains a relay coil (whos resistance does not change with temp), and two different metal conductors.
    I have found the resistance of the circuit at 20 degC using the two different temperature coefficients.
    1. How do I fit the two different temperature coefficients into alpha in the equation?
    2. and, as R1 contains two different resistances which will rise with temperature at different rates, how do I split them?
    Any help appreciated.
    Thanks in anticipation.
    edit: Has this got everyone as perplexed as I am?
    edit 2: I'm getting a bit desperate now!!
  2. Ron H
    Apr 14, 2005
    You need to post a schematic.
