what is the name of good accurate cheap temp sensors that measure voltage drop
for the gas stove heat range.. maybe 100-300 degrees... and a good source for them mail order....its for measuring pipe temp on the vent pipe...
That's a harsh environment. You are probably going to be stuck with using a thermocouple. You can get on the Omega Engineering website and see how to do it.
