Temp Sensor on 8051F320
Discussion in 'Embedded Systems and Microcontrollers' started by gusmas, Mar 4, 2011.
  1. gusmas
    Thread Starter Active Member
    Sep 27, 2008
    239
    Hey
    Ok so am using keil microvision 4, and I am using the onboard temp sensor in the micro controller, now I configured the ADC inside the micro to use a interrupt when a conversion is complete, the only problem I have is to simulate my code, since the it seems in my case the interrupt cant be generated in my code, i have to go trigger the interrupt myself in peripherals on keil v4. My code is below, just need a verdict if my code is going to work or not.
    Code ( (Unknown Language)):
    1.
    2. #include <c8051F320.h>
    3.
    4. void init_clock(void);
    5. void init_UART(void);
    6. void init_tempSensor(void);
    7. void init_ADC(void);
    8. void ADC_Interupt(void);
    9. sbit en_ADC = ADC0CN^7;
    10. unsigned int temp;
    11. void main (void)
    12. {
    13.     init_clock();
    14.     init_UART();
    15.     init_tempSensor();
    16.     init_ADC();
    17.     EA = 1;
    18.     en_ADC = 1;    //enable ADC0
    19.     while(1);
    20. }
    21.
    22. void init_clock(void)
    23. {
    24.      CLKSEL = 0;             //Selects internal clock
    25.      OSCICL = 0;             //clear the internal clock calibration
    26.      OSCICN = 0x83;         //System Clock is devided by 1. SYSCLOCK  = 12MHZ
    27. }
    28.
    29.
    30. //Baudrate is 9615
    31. void init_UART(void)
    32. {
    33.      CKCON = 0x01;             //Configure prescaled bits to devide the system clock by 4.
    34.     SCON0 = 0x50;            //RI0 will only be activated if stop bit is logic level 1.
    35.       TMOD = 0x20;            //Timer 1 configured in 8-Bit auto reload
    36.       TH1 = 100;                //TH1 reload value
    37.      TR1 = 1;                //Timer 1 start
    38.      TI0 = 1;                //Transmit Interupt of UART is enabled
    39. }
    40.
    41. void init_tempSensor(void)
    42. {
    43.      REF0CN = 0x07;           //Enable temp sensor, analogue bias generator, internal voltage reference is used.
    44. }
    45.
    46. void init_ADC(void)
    47. {
    48.     ADC0CF = 0x1C;          //Configure SAR Conversion clock and left justify configuration for ADC0
    49.     ADC0CN = 0x10;         //ADC0 in Lower Power Mode,Normal Track Mode,ADCBUSY bit is set.
    50.     AMX0P = 0x1E;         //ADC0 Positive Input is In Chip Temp Sensor
    51.     AMX0N = 0x1F;          //ADC0 Negative Input is ground, also know as being configured in Single Ended Mode
    52.     EIE1 = 0x08;           //Enable ADC interrupt when a conversion is complete
    53.
    54. }
    55.
    56. void ADC_Interupt(void) interrupt 10
    57. {
    58.      AD0INT = 0;
    59.      temp =  ADC0L + (ADC0H <<8);
    60. }
    61.
    62.
