Temp and Humidity sensor 1-5V output
Discussion in 'The Projects Forum' started by bowlingo, Feb 5, 2012.
  1. bowlingo
    Jun 29, 2011
    162
  2. bowlingo
    Jun 29, 2011
    162
  3. wayneh
    Sep 9, 2010
    12,368
    3,224
    For temperature I'd consider a much cheaper approach, a thermometer IC such as the LM35. The specifications for the device address accuracy, and perhaps it's good enough for you.
    Humidity is tougher. Most home units use a plastic strip that changes size depending on ambient humidity, tripping a mechanical switch. But there are better approaches. In industrial controlled-environment rooms, I've seen genuine wet bulbs, which of course have to be maintained with fresh water. They're nice because you don't need to calibrate a humidity sensor - just the temperature probe.
  4. BSomer
    Member
    Dec 28, 2011
    433
    106
  5. bowlingo
    Jun 29, 2011
    162
    The one on the mikroelectronica site would be ideal but the only way I think i can get it to work is by putting the board in a small adapatable box with vent holes in then wire it back to the picplc...would need to be about 5-10 metres...do you think its possible
    http://www.mikroe.com/eng/downloads/get/1547/sht1x_manual_v100.pdf
  6. BSomer
    Member
    Dec 28, 2011
    433
    106
    I don't think that remote mounting of the sensor would be a problem. I would use some sort of shielded cable to help eliminate emi or other interference. They also have another sensor that comes without the dip switch and is smaller. That one could go in a really small enclosure.
    I only suggest the ones from mikroe because of available library examples and being compatible with your specific mcu without modification.
  7. MrChips
    Oct 2, 2009
    12,623
    3,451
    Vaisala and Honeywell make temperature and humidity sensors but they're not cheap.
  8. bowlingo
    Jun 29, 2011
    162
    Where is the one without the dipswitch on the mikroelectronia site?
  9. nigelmercier
    Oct 9, 2010
    10
    IMO it's easier, cheaper and better to use a sensor with a digital output.
  10. bowlingo
    Jun 29, 2011
    162
    I e-mailed mikroelectronica and they are saying this will work...add on board, in adaptable box on long cable...
    Any ideas on a 10m screened cable type to use?
  11. BSomer
    Member
    Dec 28, 2011
    433
    106
    http://www.mikroe.com/eng/products/view/368/sht1x-proto-board/
    As to the cable...
    Well it is really up to you how you do it. I think that any shielded cable would do fine as long as it has the correct amount of conductors in it. I think you only need 4. You may be able to get away without the shield and use something like CAT5 networking cable. Build it up with that and test it to see if you are getting any errors in the data. If you have no errorsm you are good to go. :)
    Brian
