tell some some good buffers ic name
Discussion in 'The Projects Forum' started by dark dagno, Feb 2, 2009.
  1. dark dagno
    May 5, 2008
    8
    i want to control an unknown circuit (that is i dont know that circuit produces ac or dc and aslo i dont know its the voltage or current ratings)
    but i want to control that circuit so that i need a buffer when the control ip is high that should pass the signal (may be dc or ac) output of the buffer and hence i have my control on the output of the circuit
    plz tell me such an buffer ic it should access on both ac and dc input...
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    For that vague a requirement, about the only device that will be so flexible is a relay. We can't be more specific without a good idea of current and voltage or the control signal.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    For your willingness to go boldly into the unknown, I nominate thee for a Darwin award upon the successful completion of the requirements.
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    With the specification given: "unknown voltage and current" the only safe option is one of the gigantic contactors used in power grid distribution. I don't think any of those come on a chip.
  5. Skeebopstop
    Jan 9, 2009
    358
    lol, SMD contactors.
    Just throw a PTC resettable fuse on the output of a driver rated for a few amps. I am assuming you are dealing with safe voltages, nothing in the LV range (>50DC)
