What is your application?
Explain what you want to do with the IRF640. Just saying that you want to use it for switching doesn't tell us very much, as that is what they are designed for.
Note that MOSFETs are generally not the best kind of switch to use for circuits >200V, or for AC control.
Not without a lot of loud noises, bright flashes and smoke.
The IRF640 is not suitable for your requirements. It will die within moments.
Is this the same design as you presented here: http://forum.allaboutcircuits.com/showthread.php?t=40203now i am controling the to main line (220 AC)which is parallel and one line is active at a time and for this purpose we use the IRF640.
by Aaron Carman
by Aaron Carman
by Jake Hertz
by Duane Benson
