Television Convergence Board Soldering Question?
Discussion in 'The Projects Forum' started by philadelphia1, Jun 25, 2016.
  1. philadelphia1
    Jun 24, 2016
    5
    I'm hoping you kind professionals can help me with a problem I'm having soldering an convergence IC to my televisions Pcb board. The convergence went out on my projection screen television, so I purchased new IC's and removed the old ones with a desoldering iron that has a vacuum bulb. With the new installation I can't get the solder to stick to IC pin # 3, the solder wont take to the board. Perhaps I pulled a pad if in fact there is one? I'm not sure if there was one even there?. Or perhaps the board is oxidized? Please have a look at the attached picture, the pin I'm having trouble with is #3 and is circled in red. If you blow it up its easier to see. I tried to sand it very lightly with a fine nail file followed by and isopropyl Q-tip clean-up and still cant get it to take to the board. I'm a novice but really enjoy learning. Any help and guidance you folks can provide is greatly appreciated!
    Thanks,
    -Shawn in Philly
  2. tracecom
    Apr 16, 2010
    3,884
    1,396
    I am afraid you have ruined that pad and maybe some of the others. At this point, you have to start considering adding some wire bridges to connect the pins to what remains of the tracks. Difficult to do! I hope I am wrong and someone else will have a more helpful opinion.
  3. philadelphia1
    Jun 24, 2016
    5
    Thanks for the quick reply tracecom! I was able to get the solder to stick to every other pin/leg except #3 which is allocated to the mute function on the tv according the schematic
    Moderators note: removed white space from picture
  4. DickCappels
    Aug 21, 2008
    2,792
    678
    Does your projector have a feature that relates to the mute pin? If the pin you are having trouble with is pin 3, it might not need to be soldered.
  5. philadelphia1
    Jun 24, 2016
    5
    I was thinking the same thing by looking at the schematic but wasn't sure? I believe it relates to an external mute function. Thanks for your input Mr Capples! its appreciated.
