Telephone Circuits
Discussion in 'General Electronics Chat' started by Ahmed, Aug 24, 2005.
  1. Ahmed
    Mar 16, 2005
    17
    I need some tutorial about Telephone circuits
    if any body know .......... please help me
    thankx for all
  2. mawgadog
    Member
    Aug 22, 2005
    23
    can you be more specific on what it is you want to know?
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Is this what you had in mind?
    Telephone Circuits on Dave's Discover Circuits Website
    hgmjr
  4. Ahmed
    Mar 16, 2005
    17
    i need to know how we hear dial tone at off-hook case
    and what the voltages levels allocated on telephone
    i.e. at on-hook state the voltage on telephone from central is 48v - dc
    and at off - hook its dropped to 9v - dc
    can we replace the central by 48v-dc and it will work or not.
    thankxxxxxxxxxx
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Telephone systems are not created equal.
    When the set is "on-hook," it presents an open circuit to the central office. (Note: "central office" is a very misleading term. "Central office" in American telephony can refer to a circuit card in the big green box down the street. This same term can refer to your PBX. If you are running V/IP, then the "central office" is your server.)
    The CO detects a drop in impedence when the set goes "off hook" and then generates the dial tone.
    Ring voltage can exceed ninety volts. This will most definately get the attention of the apprentice technician who is leaning agianst the 66-block!! :eek: (To be fair, I've seen at least one journeyman technician make this mistake as well.)
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    ahmed,
    Here is a link to the page on the HowStuffWorks website that provides a pretty simple explanation of the basic operation of a telephone.
    How Stuff Works Website
    hgmjr
  7. Shams soomro
    Feb 6, 2008
    Super Moderator
    The central office sent called party a ring AC msignal of 90 v 20 HZ which is
    super imposed on local -48 dc supply to telephone set through subscribers loop then how ring voltage exceeds 90 volts
  8. Shams soomro
    Feb 6, 2008
    Why there is need of transforming anolog signals into digital signals for transmission??????????
    THANKS
    SHAMS........
  9. cumesoftware
    Apr 27, 2007
    1,330
    11
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    No.
    The CO detects DC current drawn by an off-hook phone then generates the dial tone.
  11. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    DC current increases as a result of the drop in impedance. Ohms Law subjected to algebra.;) Typically, less than 10mA will be drawn with the phone on-hook, and more than 15mA will be drawn with the phone of-hook. At 48Vdc, that means less than 3200 Ohms off-hook versus more than 4800 Ohms on-hook.
