AlbertHall
- Joined Jun 4, 2014
- 12,346
Collector of Q1316 at -3.2V is much lower than the marked value of +1.6 which suggests the oscillator is being driven harder.
However, there is a diode to ground connected there (CR1316) which should prevent any voltage lower than -0.7V or so.
I can't see that it would cause your present problem but do check that diode.
Can you get the 20MΩ resistor?
