Technics SU-V707 Repair - diode help!
Discussion in 'The Projects Forum' started by RidDleZ, Apr 2, 2011.
  1. RidDleZ
    Apr 2, 2011
    11
    Hello all! I am sorry if this is in the wrong section, if it is please let me know :)
    I'm repairing a Technics SU-V707 Receiver, the pre amp stage had a few components blow, and of those I've found replacements for all of them but two diodes. Technics is a Panasonic brand, so the diodes are Panasonic models.
    One is a 20A90 Geranium diode, which I had a hard time finding specs on, however I think I have found a suitable Schottky replacement - here.
    And the other is a MA2 Series MA2B027WA diode - here. It is some kind of variable resistor diode, which I cannot find a replacement for. I was curious if I could use a TVS diode in its place?
    Here is a snap of the circuit they are implemented in - here.
    Diodes D316 and D326 are the diodes of quesion.
    Any help or suggestions would very greatly appreciated!
    Thank you all for your time.
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    Hey Welcome
    The germanium diode can be replaced with OA91.
    As for the MA2. this is something I have been fighting with.
    As far as I have checked this diode Vf drop is 1.1V and this voltage is a must for proper biasing for the Voltage drive Stage. If you want the THD to be below 0.04% or so. What I did is I used two 1N914/916/4148 combination's in series and checked for the voltage drop using a supply and a resistor.. You might need to try a couple of them to get the exact 1.1V .
    If you have checked the forum you would find that there couple of threads concerning those diodes from the infamous Technics
  3. RidDleZ
    Apr 2, 2011
    11
    Thank you for the quick reply!
    I will check the forum some more and see what I can come up with. As for the 1N914/916/4148 combo's in series, what supply voltage are you using?
  4. R!f@@
    Apr 2, 2009
    8,785
    771
    Low voltage....resistance combination should be as per data sheet forward current specs.
    With those If value Vf should be 1.1VDC
  5. RidDleZ
    Apr 2, 2011
    11
    Alright, I've done some research.
    I removed one of the good MA2 diodes and tested with 5 Volts DC and adjusted a POT for exactly 3 mA as per the datasheet. The voltage drop was indeed exactly 1.1 vdc. I then took two 1N4148's that I had laying around and hooked them in series in the same circuit. The voltage drop was also, to my surprise, exactly 1.1 vdc also.
    So should the two 1N4148 diodes in series suffice as a replacement MA2? Or am I completely neglecting some factor..
  6. R!f@@
    Apr 2, 2009
    8,785
    771
    It's what I tried. To my surprise it works for me. Try it but do not over drive the amp.
    You should be checking the voltage drive biasing from time to time to see how it holds for temperature variation.
    The Panasonic diode has very good temp tolerance. I am thinking of using a TL431 as the 1.1V bias as a replacement for the diode. Not sure how yet but it is one thing that I am doing as time permits.
    I have a job that requires this diode and need to find a permanent replacement
  7. RidDleZ
    Apr 2, 2011
    11
    I will try it and let you know how it works. I will be ordering the rest of the parts I need from mouser later, so I'll let you know once I get it all back together again. As for the TL431 I may want to mess around with that and see if I can't figure something out as well. A permanent solution would be great!
    Thank you for your help, I'll be getting back with you shortly!
  8. RidDleZ
    Apr 2, 2011
    11
    Hello again!
    I've gotten all the parts in, and tried firing it up. Right after I push the button I see a nice firework show. Resistors R358, R364 and Thermistor TH302 burned instantly. I then investigated the circuit and found Diode D320 was now bad.. Any ideas anyone? I'll investigate it more a little later and post up.
  9. R!f@@
    Apr 2, 2009
    8,785
    771
    Unfortunately ...I forgot to say not to fire up before preliminary checks....Sorry u have leaned it the hard way.
    I have done a lot of fixing in technics here and yuo should follow my lead to avoid further smokes.
    First off all u shud remove the Current drive circuitry completely.
    And go on fixing the voltage drive.
    After u are sure about the voltage stage then u shud reconnect the current drive.
    But before all tht, you have to make sure the current amp has not shorted, good news is they are pretty tough suckers.
    Your voltage preamp IC could be ur main culprit.
    Every time the voltage stage fails ( which is the main failure i have came across) the diodes, current mirrors together with few diodes and the driver goes up in smoke.
    So post what have u done. I think u need me to play a major role in helping u.
    I have to guide u very intensively on this. are u game enuf? :D
    {ed}
    to make things worse, u have a transistor Output stage. I had always dealt with Hybrid types.
    But it's not tht I have not fixed this type of other brands.
    Can u send me the Schematics. My collection is missing that model.
    May retched has it in the CD tht I bought. Have to ask him.
  10. RidDleZ
    Apr 2, 2011
    11
    Oh yes, I'm game.
    I've dabbled in fixing plasma tv's and such, and am always up for learning something new. Also, I very much appreciate your help in this!
    I could not find the exact transistors, so I found ones with the same characteristics. - I hope this is not a no no, I've had luck doing this before.
    The parts I've replaced are:
    Power Amp:
    Q325,326 -Replaced with NPN FJA4313
    Q327,328 -Replaced with PNP FJA4213
    Pre Drive:
    Q318 -Replaced with NPN 2SC2705; was 2SC2631
    Drive:
    Q322 -Replaced with NPN 2SC5171; was 2SC2592
    Q324 -Replaced with PNP 2SA1930; was 2SA1112
    Diodes D316,322 -Replaced with 20A91 and D326 -the the series fix
    Thermistor TH302 and resistor R358.
    Q318 and R358 were visually burnt.
    How would you like me to send you the schematic?
  11. R!f@@
    Apr 2, 2009
    8,785
    771
    I am downloading a schema for this right now.
    After that I 'l check ur model
    dang!!! I'm having problem downloading.....it just sits there.....
    It seems FSM does not have ur model. Can u email me the schema
  12. RidDleZ
    Apr 2, 2011
    11
    Did you get my E-mail with link to the manual?
  13. R!f@@
    Apr 2, 2009
    8,785
    771
    I can't seem to find it. What's the name and subject of ur email.
    Just click on my nick above and email it
  14. RidDleZ
    Apr 2, 2011
    11
    I have sent it again.
  15. R!f@@
    Apr 2, 2009
    8,785
    771
    checking........
    {ED}
    Got ur mail..but the site gives me server reset eror.
    Try attaching the schema to my hot mail. it is the best option
  16. RidDleZ
    Apr 2, 2011
    11
    Please forgive my ignorance, but I cannot find your hotmail address. It does not show me, and I cannot find how to add an attachment.. lol.
  17. R!f@@
    Apr 2, 2009
    8,785
    771
    Funny..
    It's OK..I got it. Let me go through it first.
  18. RidDleZ
    Apr 2, 2011
    11
    Hey, not to bother you, but have you had a chance to go through the schematic?
  19. R!f@@
    Apr 2, 2009
    8,785
    771
    Ya..Have u got the replacement parts ready?
  20. RidDleZ
    Apr 2, 2011
    11
    Yup, should have all the ones needed.. and extras. Guide me through this jungle of circuitry.
