Technics current drive problem on a vx800
Discussion in 'General Electronics Chat' started by mickmick, Jun 7, 2012.
  1. mickmick
    Jun 7, 2012
    Hi!
    Got a friend that got a su-vx800 that not want to start in current drive stage, only the first amp comes on.
    It happends after playing pretty hard with it for a whole weekend :D
    Some tips,PLS:confused:
    I live pretty far from him and cannot search for the problem(mostly because for spareparts delivery time doe i only will visiting him for a day!) when i visiting him, therefore i "want some meat on my legs"(directly a swedish translation)before i can take a look att the amp!
    Manual:
    http://www.opweb.de/model.php?id=881
    Thanks in advanced
    Mike
  2. #12
    Nov 30, 2010
    16,704
    7,354
    If you posted a schematic here, we could try to be helpful. Without a drawing, it is all guessing.
    I uploaded the drawing so ppl don't have to go to your link.
  3. mickmick
    Jun 7, 2012
    Done, excuse me!
    Mike
  4. mickmick
    Jun 7, 2012
    I know it will be pretty hard 2 find the faulty component without measuring. Im most curious if someone else had the same problem!
    Mike
  5. R!f@@
    Apr 2, 2009
    8,792
    771
    Tell me a bit more.
    {ed}
    That model has transistors at the output stage. First U need to check for shorted power transistor for shorts.
    U can check for short without removing. U will need a good DMM.
    The meter needs to be in diode check range. Before testing, make sure the power is off and the filter caps are completely discharged !
    U need to make sure that none of the power transistors mounted on the heat sink does not have a short between CE.
  6. mickmick
    Jun 7, 2012
    Okey, TNX!
    Where is the "connection" between output stage and the current drive stage?
    Is it the overload curciut?
    Mike
  7. R!f@@
    Apr 2, 2009
    8,792
    771
    No...these are the Current amplifier and is the final stage of the Power amp.
    There will be I thing eight Power transistors mounted on to the heat sink. Big ones. If u miss these, u need glasses mate.
