The designation of "senior member" is earned when the member submits their 100th post.Thanks. i heard you are a senior member how does one become
a senior member.
thanks for the advice.We become Senior Members by contributing to the forums.
The XR2206 is not a particularly easy IC to use, nor to obtain. If you have one, I suggest that you experiment with lots of cheap IC's first, so that your XR2206 will still be working when you'll be able to put it in a "good" circuit.
If you are not careful, you will very quickly destroy it.
is 555/556 Op-amp similar to XR 2206.?Why not start with 555/556 timers, and/or making a function generator out of several opamps? There are quite a few schematics around for such things.
Opamps and 555/556 timers are very cheap nowadays.
I believe the device was introduced by Intersil. EXAR had a similar part.is 8038 made by XR company.
Ridiculously expensive.NTE864 is the same thing, but ridiculously expensive.
how expensive are we talking about?
$ 51 for a IC are you sure?Check Mouser's price for the NTE864 (might be part number 538-nte864). I got a couple for $8.40 a year or so ago.
No - it's 526-NTE864, but the price is now $51 and change. Not worth it!
even $ 4.80 seems a little high, this must be a expensiveYes. That is a real rip-off. I used to pay $4.80 for the ICL8038CCJD from Intersil.
