affirmativeOk so which amplifier would you recommend? This one? http://www.ebay.com/itm/TDA7297-DC-...405?pt=LH_DefaultDomain_0&hash=item486813868d
How many sound bites do you plan to use? When do you want them to play? Each sound bite will be an output from your processor.I'm gonna say that I'd rather go with the 200S USB MP3 for the sounds. It may not be that loud but considering how iconic the tf2 sentry sounds are it may be loud enough. Plus I already have access to the sentry sound clips through the game itself, I just need to edit them down to just their sounds minus the background noise, plus covert them to mp3 format to work.
OK, let's get our terminology straight. It's not a wireless Arduino. It's simply a 4 channel receiver with digital outputs. That means that you have to connect these outputs to the 18M2 inputs. In a previous post I suggested that you use the C-ports for inputs and the B-ports for outputs.Finally! I thought I'd never get help with this, and its been doubly stressful cause I'm running out of time. Anyways...
Here's what I have so far.
What I still need to get
- PICAXE-18 Standard Project Board
- PICAXE-18M2 microcontroller
- AXE027 PICAXE USB Download Cable
- IC 2262/2272 4 CH Key Wireless Remote Control 315MHZ Receiver module F Arduino
I found a manual online for the Picaxe standard project board but I have no idea how to wire it to the wireless arduino, I haven't tried to download a programming application for the microcontroller/project board and I have a concern that this board can't handle a sound output other then a buzzer
- Battery pack
- Output speaker
- Bright LED
Yea the con I'm going to starts july 17th, so I need to get all my parts and get the whole thing wired up before then. And the other major problem hindering me from moving forward is money... I won't get paid till july 1st, which will be the earliest I can order those parts... so that means the more local the parts are the better... if I have to wait for a part to ship in from china then its out of the question.As a side note, I see you are stressed that time may be running out. I appreciate that. However, Summer is my busy time. I am chairman of our community festival and I like to spend as much time up the camp fishing. So there may be intervals of several days or more where I don't respond to this forum. Elec-mech is an experienced guy who is also familiar with Picaxe basic. Go back and read my earlier postings and you will see that I posted a basic schematic of how all this connects. Please review this as well as the wealth of information on the Picaxe site.
Sorry sorry. Just 3, a beep, a chirp beep of alert, and then the sound of the sentry firing in rapid succession. I haven't assembled the sentry yet for good reason, the list of parts I have to put into it keep getting bigger and bigger so I need to make sure everything fits in the little thing. And well lets see.Have you built and assembled the turret yet? Have you generated a list of inputs and outputs? Have you answered my questions about the sounds in Post #42? The last two so I can get started on programming. Lots to do and so little time.
There is no good reason for not having assembled the turret. You started this thread in April and now with the convention less than three weeks away do you seriously think this will come together within that time frame? Seems to me that is as much of a fantasy as your gaming. I seriously doubt you will finish the turret assembly within the time frame you specify, much less construct the electronics and software. I am more than willing to help, but come on, you have to put some sweat equity in to this project. Trust me, I appreciate the fact that funding is an issue. I'm retired and on a fixed income. So it is doubly difficult for a student. (You never told us your major). Again, cash flow vs. project time line seems to be out of synch here.Sorry sorry. Just 3, a beep, a chirp beep of alert, and then the sound of the sentry firing in rapid succession. I haven't assembled the sentry yet for good reason, the list of parts I have to put into it keep getting bigger and bigger so I need to make sure everything fits in the little thing. And well lets see.
Like I said with elec mech. I only plan on using three buttons on the wireless remote. One to turn it left, the other to turn it right, and the last one to fire the sentry. Once no activity has been picked up in 5 seconds it will return to idle and turn from left to right while beeping. Also when I turn it it will make the chirp sound. Now as for output, it will need the three buttons for the speaker noises, plus the light when the 3rd button is pressed, and the servo when its turning.
If you can do that in one day then your a better man than I (to paraphrase Kipling).I can put the whole turret together in one day. The one thing I'm having trouble getting my mind around is how to mount the top part to the stand and still make it rotatable.
AffirmativeBad news is the amplifier you listed is no longer available. Will this one work? http://www.ebay.com/itm/TDA7297-DC-...ffType=OrderSubTotalOffer&_trksid=p5731.m3795
In order to communicate with the project board, the 18M2 must be correctly inserted in its socket and power must be supplied to the board. CAUTION! DO NOT USE MORE THAN 4.5 VOLTS (3 ALKALINE CELLS)Also I did have a problem with the picaxe programmer. My laptop still doesn't recognize the board when its plugged in via usb, is that because I need to have a power supply running through it? Like the battery pack I need to get?
Now that you're rolling in dough, I strongly suggest that you go to the following website:GOOD NEWS I just checked my account and I got $55 more from a sale I made on ebay a while back. I'm purchasing parts right now!
all ordered and on the wayNow that you're rolling in dough, I strongly suggest that you go to the following website:
http://www.jameco.com/webapp/wcs/st...splay?langId=-1&storeId=10001&catalogId=10001
and order the following parts:
10 ea. - P/N 189676 terminal blocks
2 ea. - P/N 109576 male headers
1 ea. - P/N 1954818 4" speaker
2 ea. - P/N 2205341 White LED
while your at it, order some 150 ohm, 1/4 watt resistors. You need these to limit current to the LEDs
The speaker I recommended is $4, how much cheaper do you want to get. On the one hand you expressed concern about the short time frame, then you want to go shopping Goodwill in the hopes of finding the right part. Go figure! Have you even gone to the Jameco site to see what the total spending would be for the parts I recommended?I had a cheap solution/question for the speaker and the battery pack. Could I go search for a cheap radio at good will and salvage the parts from that?
And if so, what battery type should I look for in the radio? Cause if I understand this correctly, the right battery type/number of batteries will equate to the proper voltage/wattage for the speaker.
Wouldn't that be a bad thing?but you may end up spending more on batteries than the total project cost.
forget my last post - didn't see this one. Let me know when you get the parts from Jameco, we have work to do on your project board.all ordered and on the way
Walmart, Radio ShackFine fine it was just a suggestion to shortcut costs and or find something immediate in terms of batteries so I could start programming now. Anyways where do I get the alkaline cells? I don't remember you listing a site in your earlier posts. I'll check again and amend my post if I see you did mention it but other than that I searched Jameco and all I found were specialized offbrand batteries.
by Jake Hertz
by Duane Benson
by Jake Hertz
