Tea Kettle Bell
Discussion in 'The Projects Forum' started by Stanley83, Jan 9, 2014.
  1. Stanley83
    Jan 9, 2014
    5
    First post, please be gentle.
    I have an electric kettle that turns off when the water boils, but gives no indication that it has done it's job. I would like to figure out how to wire up a bell that will chime once when the pot is no longer drawing current. I assume my best plan of attack would be an AC relay that would trigger the bell, perhaps using a 555 chip, but beyond that, I'm out of my depth.
    Any help would be appreciated,
    Justin
  2. paulktreg
    Distinguished Member
    Jun 2, 2008
    625
    125
    A current transformer threaded onto the mains supply lead?
    ...or perhaps just simply wrapping a few turns of wire around the mains supply lead and amplifying the signal?
    Just some ideas.
  3. inwo
    Nov 7, 2013
    2,435
    315
    If there was room, and a mechanical thermostat, a buzzer could be connected across it.
    It would remind you to unplug it, as it would buzz until disconnected.
    A diagram in another thread shows a dryer buzzer connected that way.
    http://www.freeinfosociety.com/elect...ew.php?id=1564
  4. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Microswitch actuated by the pop-up lever on the kettle switch?
  5. tracecom
    Apr 16, 2010
    3,879
    1,396
    Whistle on the spout? :D
    shortbus and tshuck like this.
  6. Stanley83
    Jan 9, 2014
    5
    Alas, the design of the kettle precludes a whistle. I was hoping not to modify the kettle itself, rather make a box with a socket that the kettle would plug into.
    Would a 555 be cooked if the switch was normally in the "on" position and turned off only when current was flowing?
  7. Alec_t
    Sep 17, 2013
    5,980
    1,138
    You'll need to explain that. Which switch are you talking about? One at the mains socket, or in the kettle, or for the 555 supply?
  8. Stanley83
    Jan 9, 2014
    5
    My idea was to have an AC relay open the trigger switch for the 555 when the kettle was drawing power and close it when it shuts off. This would mean that the 555 trigger would be normally closed, except when the kettle was in operation. Is this clear?
  9. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Much clearer :). What will you use to power the 555 and 'bell': batteries or wall-wart?
  10. Stanley83
    Jan 9, 2014
    5
    wall-wart, I've tons kicking around.
  11. tracecom
    Apr 16, 2010
    3,879
    1,396
    And how is it you plan for your 555 to know that the kettle is on as opposed to just plugged in?
    I can't help but believe there is a way to use the water temperature or steam temperature more easily. Even if it was only a thermistor positioned over (or on) the kettle spout.
  12. BobTPH
    Jun 5, 2013
    807
    121
    If you are always heating the same amount of water, a timer would do the trick.
    Bob
  13. inwo
    Nov 7, 2013
    2,435
    315
    Start with one of these..................................
  14. shortbus
    Sep 30, 2009
    4,097
    1,695
    The kettle probably uses a thermal snap switch to control temperature. Using it to also trigger a buzzer, through a relay, should do what you want. If it doesn't use a thermal snap switch, adding one to trigger the buzzer directly could also be done. The snap switches are available in many different temperature ratings - http://www.comstatinc.com/thermostats/snap-disk You can even get them on Ebay.
  15. Stanley83
    Jan 9, 2014
    5
    These look just what I'm looking for, a little pricey, though.
    My hesitance to modify the kettle itself is that the kettle sits in a base where it gets its power. With this design, the wiring stays behind when the kettle is carried to the tea pot or coffee cone.
  16. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Personally I'd go with Tracecom's suggestion (post #11). A matchbox-sized gizmo could hold a bit of circuitry, beeper and couple of CR2032 batteries and hook over the spout, with a thermistor in the hook.
    tracecom likes this.
  17. inwo
    Nov 7, 2013
    2,435
    315
    Smart power strip.:)
    Plug kettle into main outlet.
    Plug a 9vdc battery powered "not" buzzer into a slaved outlet.
    ps.
    Anyone hacked one?
    Power rating?
    Internal relay with a nc. contact?
  18. djsfantasi
    Apr 11, 2010
    2,911
    881
    If the kettle gets it's power from the base, I would think you'd include a current sensor in the base or added to the base. That way per your requirement you would not be modifying the kettle (pot). Or am I misreading that restriction?
  19. inwo
    Nov 7, 2013
    2,435
    315
    I wonder if the thermostat is in the base.
    A buzzer across the thermostat is still the simplest.
  20. inwo
    Nov 7, 2013
    2,435
    315
