TDA8920bj mode switch
Discussion in 'The Projects Forum' started by tiggerlator, Jul 11, 2014.
  1. tiggerlator
    Jun 7, 2014
    16
    How do i mode switch a 8920bj using pin 23? i need to power on the module to operating mode.
    I know it is using pin 23 but don't what to connect to it.
    Here is a link to the service manual for the panasonic amp i am diy'ing. I am using the DAMP board and the SMPS power board. I have removed the reciever module board from it's slot in the DAMP board.
    I hope you guys can help, I want to use it for speaker power for my rotel rsp-960ax pre amp.
    http://diagramas.diagramasde.com/audio/SH-FX65P.pdf
    thx
  2. DickCappels
    Aug 21, 2008
    2,783
    676
    Pin 23 of WHAT??????
    Also, in what part of the schematic are you looking?
  3. tiggerlator
    Jun 7, 2014
    16
    pin 23 of the tda8920bj !!!!!!!! think that would have been obvious, and page 40 of the service manual.
  4. Alec_t
    Sep 17, 2013
    5,980
    1,138
    See page 6 and Fig 4 of the NXP datasheet for the TDA8920bj.
    tiggerlator likes this.
  5. tiggerlator
    Jun 7, 2014
    16
    Thx Alec, it will be ok without the reciever board yes? it is really high quality made, all elna and nichicon caps.
    Ahh yes, what are the two components with R on them? resistors, but what value.
  6. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Don't see why not (but I haven't ploughed through the service manual).
    I'd try both R=15k, C=47uF. The time constant should be at least 500mS to prevent switch-on pops.
  7. Dodgydave
    Jun 22, 2012
    5,167
    777
    Looks like its a Mute pin, provided by Q1006 page 40 datasheet.
  8. tiggerlator
    Jun 7, 2014
    16
    It is, kind of, it seems to switch from mute, standby or operating. The actual panasonic unit does have a power switch for main power, but i am guessing the reciever board controlled mute/standby/operate via pin 23. It is pin 6 on the 8920bth which is smd mount. BJ version is mounted upright with pin through the hole.
  9. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Unless you want to add a switch or two to select mute and standby manually, I'd just connect a 47uF cap on pin 23 via a 10k resistor to the 5V line. The amp would then be muted at power-up and go into operational mode ~ 500mS later.
  10. tiggerlator
    Jun 7, 2014
    16
    Oh thx, that is how i will do it.
    Like this?
    Really appreciate you taking your time to help me.
    Tiggerlator
  11. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Not like that. Check the datasheet (Fig 4). Note that the cap connects between pin 23 and ground. The R would go between pin 23 and +5V.
  12. tiggerlator
    Jun 7, 2014
    16
    ok thanks for your help.
  13. tiggerlator
    Jun 7, 2014
    16
    it powers on after a second or so, but i'm not getting nothing from the input. I can hear a hiss from the speaker if i put my ear to it.
    I have tried the following input connections.
    pins 1 and 3 on cn1000 which is the socket the reciever board was in, and pins 2 and 22 on the 8920 module.
  14. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Why pins 1 and 3? According to the Service Manual, the L and R audio is on pins 2 and 4 of CN1000.
    Edit: BTW, the Manual shows the L and R surround speakers shorted together!. That can't be right.
  15. tiggerlator
    Jun 7, 2014
    16
    I have it connected to pins 2 and 4 of cn1000 meant to put 2 and 4, not 1 and 3, i have ground on pin 1 of cn1000. I did try pins 2 and 22 of the 8920 ic direct too but still no output. The input is coming from my rotel pre amps outputs.
    I'm not sure on the shorted outputs, but i do get a real low hiss from the speakers when it is powered up, so i'm sure it is powering up now.
    I appreciate the help.
  16. Alec_t
    Sep 17, 2013
    5,980
    1,138
    I'm unclear as to your exact setup.
    If you're not using the receiver board, are you now supplying the Rotel pre-amp outputs directly to pins 2 and 22 of the 8920? Or are you using the 'High-pass filter and Pre-amp' section of the Sony system?
    Apart from the R and C discussed above, is anything else connected to pin 23 of the 8920?
    What is the voltage at pin 1 of the 8920?
  17. tiggerlator
    Jun 7, 2014
    16
    nothing, just the R and C. I don't have a multi tester to test voltage but i will try and borrow one today. I will also post a pic of the board with the connections i have done ok.
  18. tiggerlator
    Jun 7, 2014
    16
    sorry for delay.
    Pin 1 to ground with it powered on is 25.1v
    Nothing else connected to pin 23.
    I guess i don't need to use the receiver board, that is only for its original use.
    I have tried connecting directly to pins 2 and 22, and also to pins 2 and 4 of cn1000.
    I am connecting the input to the damp from the pre outputs of my rotel amp, these would normally go to the power amp.
  19. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Still waiting for the promised pic.
    Looking at the detailed schematic in the Manual, I see that pin 23 of the TDA IC already has an R and C connected (R1007, C5602), so you shouldn't need any additional components there. But if you don't have a receiver board plugged into CN1000 then you will need to make connections to certain pins of CN1000. Pin 7 needs to be pulled high (so could connect to pin 5 via a ~47k resistor), and pin 10 needs to be low (so could connect directly to pin 1).
  20. tiggerlator
    Jun 7, 2014
    16
    I will get some pics up tomorrow ok. thanks again.
    So I can remove the R and C i added to pin 23, and connect to pins 7 and 10 of cn1000 as you have suggested?
    Cheers Alec.
