Hello again,
I am building a TDA7052A guitar amplifier with the following application diagram and volume control (on pin 4):
The power supply is 9V. The input of the TDA7052A is given from an MPF102 buffer circuit (not included in the diagrams).
I built a similar circuit using the TDA7052 feeding a 2", 8R, 1Wrms loudspeaker and 9V power supply also, without no problems.
But with TDA7052A feeding a 4.5", 8R, 5Wrms loudspeaker and 9V power supply the IC is overheating. And after one minute of play noise like farting in the background (and it comes to the surface when i lower down the tone pot of the guitar) appears . After this noise occurs the IC is permanently damaged, with my observations so far.
The question i have is if its possible the IC to get overheated because it can give its full power on the speaker (while with the 1Wrms speaker it could not)??
