tda2050-identifying connections
Discussion in 'General Electronics Chat' started by mu71b, Mar 1, 2014.
  1. mu71b
    Feb 26, 2014
    43
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    I don't understand the question since all of the tie points are labeled on the printed circuit layout and referenced on the drawing.
    mu71b likes this.
  3. paulktreg
    Distinguished Member
    Jun 2, 2008
    625
    125
    Out = Speaker Positive
    2 = Speaker Negative
    In = Signal Positive
    1 = Signal Negative
    + = Positive Supply
    - = Negative Supply
    mu71b likes this.
  4. mu71b
    Feb 26, 2014
    43
    Thanks mate, your a life saver
  5. R!f@@
    Apr 2, 2009
    8,793
    771
    Where's the Supply GND ?
    mu71b likes this.
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    Tie point #1, common to tie point #2
    mu71b likes this.
  7. mu71b
    Feb 26, 2014
    43
    sorry i'm confused could you please explain to me what you mean by tiening these points
  8. odinhg
    Jul 22, 2009
    65
    15
    I hope this helps :)
    mu71b likes this.
  9. BillB3857
    Feb 28, 2009
    2,402
    348
    A tie point is a place where two or more circuits or wires tie together. Those points (places) are identified on the circuit layout.
    odinhg has done a great job with his visual representation. As you can see, the points (connections) he tied colored lines to have numbers to identify the tie points. The gray are between point #1 and point #2 indicate that these two points are connected together or "tied" together.
    mu71b likes this.
  10. mu71b
    Feb 26, 2014
    43
    what is the supply common, 0v
  11. R!f@@
    Apr 2, 2009
    8,793
    771
    A GND or 0V is the supply common point.
    Positive and Negative supply with respect to GND.
    The common point of the two smoothing caps that is connected across the bridge.
    The center tap of the transformer
    mu71b likes this.
  12. mu71b
    Feb 26, 2014
    43
    sorry im still confused, could you perhaps tell me if anything extra needs to to be wired there or is it just a point to take , not and remeber
  13. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I have combined the picture of the powersupply from your given website with the connection diagram odinhg gave:
    I hope this will help you.
    Bertus
  14. mu71b
    Feb 26, 2014
    43
    sorry but i have been even more confuesed now, can you just tell me what is meant to be wired their as i sometimes get a little bamboozeled by certain schematics, kind regards, mu71b
  15. mu71b
    Feb 26, 2014
    43
    do i just link the negative from the battery with that grey wire, ???
  16. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    When you are using batteries, you will need two of them.
    Connect the + from the first battery to the - from the second battery.
    This will be the grey wire.
    The + from the second battery will go to the red wire.
    The - from the first battery will go to the blue wire.
    Bertus
    mu71b likes this.
  17. mu71b
    Feb 26, 2014
    43
    actually, thanks, you solved , it
