TDA2030 bass amp - distortion and noise
Discussion in 'The Projects Forum' started by imperatormk, Jul 1, 2014.
  1. imperatormk
    Mar 1, 2011
    96
    Hey.
    So I have built a TDA2030 bridge amp while completely following the schematic in the datasheet. I works pretty well when I play some music from my cellphone or when I plug in a guitar, but when I plug in my bass, the sound is pretty distorted when playing low notes. It improves a bit when I turn the treble knob all way up, but otherwise it distorts. Just for the record - when playing some music from the phone, if there is some more prominent bass in the song, there is distortion again.
    This is when plugging in any device directly, with no preamp or anything between the device and the amp.
    I tried using a simple booster circuit made with a TL072 (I think) IC. Now the distortion gets even worse on the bass side. Additionally, when the booster circuit is turned near to the max, there is some nasty sound on the output, even when there is nothing on the input of the booster (the guitar is unplugged or just nothing being played). In attachments there is a short track showing the actual noise generated. Also, the same thing happened when I use a distortion pedal and turn it up even a little bit.
    The speaker is definitely not the culprit. I use the ±12V rails from a PC PSU to power the circuit. The max current on the -12V side is 0.8A (as from what's written on the PSU at least).
    The chips are properly cooled.
    I am unsure if this could be some grounding problem (I am using shielded cable on the input BTW), or just a bad power supply, or maybe a faulty board (I double-checked the connections though), so any help is appreciated.
    Thanks!
    • rec.zip
      File size:
      29.1 KB
      50
  2. Lestraveled
    May 19, 2014
    1,957
    1,218
    Hi
    I played bass in top 40 bands through my first two years of college for extra money.
    OK, so you bridged two TDA2030 together to make a 25 watt amp, right?
    Your negative 12 volt supply is rated at .8 amps. Each amp at 14 watts out draws .9 amps. This might be your first problem, not enough power supply.
    Describe your bass speaker, speaker diameter, box volume, port size/no port.
    Mark
  3. imperatormk
    Mar 1, 2011
    96
    I measured the current on the -12V line while the amp was at peak volume - it exceeded 1A. The PSU seems to provide the needed output current.
    As for the speaker, I can't supply all the data right now, just I know the speaker diameter is 6".
  4. Lestraveled
    May 19, 2014
    1,957
    1,218
    Did you measure the voltage? How far did it drop?
    Mark
  5. imperatormk
    Mar 1, 2011
    96
    The voltage while zero load is ~-11.2V and it dropped by ~0.5V when loaded.
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    how abput coupling caps on the amps? too small, and they will limit the bass response.
  7. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Did you use a DMM or a scopeto measure the drop? A DMM would not normally show sharp large dips in the voltage; rather, it would show a sort of average.
  8. imperatormk
    Mar 1, 2011
    96
    Here is the schematic I used: http://prntscr.com/3ynf4a
    I have marked the cap that (I think!) is the coupling cap. I just followed the values recommended in the datasheet..
    I just used a DMM; it's the best option I have..
  9. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Then my guess is that bass peaks are pulling the supply voltage way below 12V and causing the distortion. IMO a more powerful and/or better regulated supply is needed.
  10. imperatormk
    Mar 1, 2011
    96
    Makes sense. But there is something else; why does the same distortion appear when the volume knob is turned down so the chances the PSU is overloaded are small?
  11. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    Most likely your TDA2030 circuit is oscillating at high frequency.
    The TDA2030 is very sensitive to layout and will oscillate at any chance given.
    I have a friend working as an EE at a germany company (ibp.de) that designs calibration standards and such for medical equipment and what not, and even he was unable to get a TDA2030 to work properly.
  12. Lestraveled
    May 19, 2014
    1,957
    1,218
    I agree with Alec. The -12 volts does not have enough current capability.
    Here is something you can try to prove it. Replace the -12 volts with a car battery or motorcycle battery.
    Also, if you can run this amp with a +-15 volt supply you will get a LOT more power out of it.
  13. imperatormk
    Mar 1, 2011
    96
    I would imagine optimizing certain parts' values could help if the circuit might be oscillating?
    I was thinking about buying a transformer with both higher power and voltage, but it's not that cheap and I need to know that the circuit will perform well after I buy it.
    Could there be a problem of any sort if I use two different power sources (like the PSU and a car battery, or maybe the +12V rail of another PSU, since I don't know if I can find a battery)?
    Thanks!
  14. Lestraveled
    May 19, 2014
    1,957
    1,218
    Using a battery and a PC power supply is no problem.
    Using two two PC power supplies (one inverted) is complicated. The common of all of the output voltages is connected to chassis and to the ground pin of the power plug. You would have to keep the two chassis separate and disconnect the ground pin (not recommended.)
    Another way is to open up the supply and find where the output common connects to chassis/ground and break(cut) the connection. Leave the chassis/ground pin connection intact for safety.
    Mark
    imperatormk likes this.
  15. imperatormk
    Mar 1, 2011
    96
    Uhm, I'll probably just cut the wire that connects the board to the chassis, because the PSUs are pretty old, so anything that might happen to them wouldn't be a big loss, and the testing time will be pretty short anyways.. I just hope I won't attend a firework show.
    Thanks for the help to this point!
  16. MrChips
    Oct 2, 2009
    12,635
    3,454
    You are not going to get proper bass from a 6" speaker.
    Also the size and design of the speaker cabinet is equally important.
    Posting a photo might help us to assess the situation.
    I play bass in a band and my home made bass amp has a 450W 12" woofer in a bass reflex cabinet.
  17. THE_RB
    Feb 11, 2008
    5,435
    1,305
    And even a 12" driver is considered less than optimal, most bass players will go for a 15" driver. Especially in heavy rock with 5 string Bass guitar (low B string).
  18. imperatormk
    Mar 1, 2011
    96
    Uhm, this is just a practice amp, and according to me 12"/15" speaker would be an overkill. I really don't need the best sound from this amp, just the fuzz part really messes everything up.
    Nevertheless, I'll send over some pics of the speaker/cab tomorrow.
    Thanks!
  19. Dodgydave
    Jun 22, 2012
    5,154
    772
    Looks like you've already been told what the problem is here by Fast Eddie, try improving the -12V side and then start with the component values.
  20. imperatormk
    Mar 1, 2011
    96
    Yeah, I forgot to mention that. Seems that the caps replacement didn't do the trick either, so I'll try the thing with the PSU today.
    Erm, I uploaded a pic of the speaker & the cab, as you asked.
    Thanks!
