TDA 2003 amplifier
Discussion in 'General Electronics Chat' started by jjkk, Feb 16, 2009.
  1. jjkk
    Jan 16, 2009
    12
    Hi all,
    I am using the test circuit that is provided by the TDA 2003 data sheet to make an audio amplifier. but the output i am getting looks like a half wave rectifier output. i cann't understand why. any help much appreciated.
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    Can you post a schematic?
    It looks like a dc offset somewhere.
    What is your powersupply?
    Greetings,
    Bertus
  3. jjkk
    Jan 16, 2009
    12
  4. mik3
    Feb 4, 2008
    4,846
    63
    Did you bias the amplifier to output a voltage of half the supply voltage when no signal is present?
  5. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    Are the capacitors in the right order ?
    Take a look at C2 direction.
    Greetings,
    Bertus
  6. jjkk
    Jan 16, 2009
    12
    i didn't bias the amplifier. i read it has its own internal biasing.
    i have (+) of C2 to pin 2 and (-) to R1 and R2 junction.
  7. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    So C2 is correct mounted.
    What is the voltage you are using ?
    It should be between 8 and 18 Volts.
    Greetings,
    Bertus
  8. mik3
    Feb 4, 2008
    4,846
    63
    At which page did you read that?
  9. jjkk
    Jan 16, 2009
    12
    i found what was going on with that. i was not using proper attenuation.now the circuit is working properly so far. thanks for all your help.
  10. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    Glad you found the trouble.
    Only 50 mV is needed to have full output.
    Greetings,
    Bertus
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    The test circuit in the datasheet does not show external basing resistors because they are built-in as shown on the schematic of the IC.
