TCS3210 light to frequency help
Discussion in 'General Electronics Chat' started by Razor Concepts, Jan 21, 2010.
  1. Razor Concepts
    Thread Starter Active Member
    Oct 7, 2008
    212
    I am using the TCS3210 to measure light intensity - did I choose the wrong chip? From the datasheet it looks like the output frequency is just proportional to the amount of incoming light, and that there is no set value to it (ie, lumens).
    http://mouser.com/catalog/specsheets/TCS3200-E11.pdf
    Am I correct that the frequency doesn't represent a certain unit of light?
  2. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    It does within the tollerance shown on the data sheet. Not a very close tollerance, you probably should field calibrate it. What it is good at is being linear.
