TCA785 phase control ic
Discussion in 'The Projects Forum' started by Alvin24, Mar 19, 2009.
  1. Alvin24
    Feb 11, 2009
    i can't get the control voltage (V11)from pin 11 in the straight line waveform when i connected the as the datasheet given. The synchronization voltage (V5) and the Ramp voltage (V10) i can get it as the datasheet stated . But the Control voltage (V11) i cant get it asstraight line as the data sheet stated. Which point i need to check for my circuits ?? HELP PLS... URGENT:confused: as the project due date is closer. Thanks :)
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Wich schematic did you use?
    There are several in the datasheet.
    Here is the first example:
    I have worked with the chip several times.
    Most times I had problems with the resistor Rsync, this must have enough power.
    I lately replaced them with 2X 470K, 1/4 Watt in parallel.
    Greetings,
    Bertus
