TCA 785
Discussion in 'General Electronics Chat' started by ramanh, May 14, 2009.
  1. ramanh
    May 14, 2009
    Hi there is it possible that someone can help me with the above Phase control IC.I'm encountering some problems with the Application example - Triac Control for up to 50mA Gate Trigger Current.I've reduce the AC voltage to 26V AC too suit my circuitry,which drives a 24V 150W halogen lamp.With this I changed some resistors for eg Rsync is 27K and the input resistor is 390 ohm and also changed the TXC10M60 with a common used TIC225M triac.
    No luck with the circuit.Help please
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Can you post the schematic of what you have now?
    I think it must be possible to let it run at your 26 Volts AC.
    Greetings,
    Bertus
