Tattoo machine triple tap
Discussion in 'The Projects Forum' started by ClipCord, May 26, 2013.
  1. ClipCord
    May 26, 2013
    13
    I started my first real electronics project today. I am building a device that will allow me to run three tattoo machines through it. The layout is as follows:
    1/4" phone plug is power in from my power supply, off of this i have 3 wires soldered to the + lead that will take power to the constant power lead of 3 SPDT mini toggles. One switched lead will not be used. The other switched lead will send power to a blue 5mm LED through a 150 ohm resistor, as well as another 1/4" phone plug for machine hookup. I tested the project just now and I get power through the switch to my machine. However, the switch does not interrupt power and the LED does not light when power is on at all.
    Can anyone assist?
    Thanks,
    Anthony
  2. MrChips
    Oct 2, 2009
    12,636
    3,455
    What is the voltage and current requirement for each machine?
  3. Dodgydave
    Jun 22, 2012
    5,155
    772
    If its one of these , then its a 1.8V to 18V DC at 3 amp psu
  4. ClipCord
    May 26, 2013
    13
    Each machine runs on variable voltage. The power supply itself generates between 1.5v - 18v DC. However, typical operating voltage can be as low as 5.5v but as high as 12.
