tapping in a frequency?
Discussion in 'The Projects Forum' started by ale2121, Apr 12, 2009.
  1. ale2121
    Thread Starter Active Member
    Mar 20, 2009
    71
    ok this is a wild idea i came up with. let's say i made a little noise oscillator. Is there any way to tap in the pulse rate? ie, manually count along with the timing of the music and then have the oscillator pulse at that rate? kinda like a metronome. my metronome allows this, but i wanted to have adjustable tones.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    I'm not sure I understand what you mean. The metronome is indepentent of the note, normally. Are you wanting to limit the duration of a note to the metronome?
