Tank circuit inductor
waulu
Joined Dec 23, 2016
62
I am designing a simple oscillator in ltspice. It's working perflectly fine, now I need to build it. The inductor of the tank circuit is 8.2uH I was thinking if I could use a fixed inductor (or whatever it's called, see the image) or if I should just stick with an air coil. This oscillator will be used in a radio transmitter. What would be the pros and cons?
Thanks.
waulu
Joined Dec 23, 2016
62
Ok I am surprised. These inductors are available with values since 100nH to 1mH and they are all the same size. I would expect the size of the inductor to increase a lot with its value. I will try it and see what happens.
waulu
Joined Dec 23, 2016
62
Ok those have "ferrite DR core", it's what is in datasheet, but they are pretty good. I bought a kit of inductors from China (I am still waiting for them) but I bet they won't be that good. Meanwhile I bought PVC to make an air coil inductor, I will use both inductors and compare the results.
