tangent planes and linear approximations
Discussion in 'Math' started by wheetnee, Oct 7, 2009.
  1. wheetnee
    Oct 1, 2009
    28
    Suppose you need to know the equation of the tangent plane to a surface, S, at the point, P(2,1,3). You don't have have an equation for S, but you know the curves,
    r₁ (t) = < 2+3t , 1 – t² , 3 - 4t + t²>
    r₂ (u) = <1+u², 2u³ - 1, 2u + 1>
    both lie on S. Find an equation of the tangent plane at P.
    i already dervied r1(t) and r2(u)
    but im not sure what the next step is.
  2. Ratch
    Mar 20, 2007
    1,068
    wheetnee,
    Well, let's see. It is easily seen that r1 and r2 pass through P(2,1,3) when t=0 and u=1 respectively.
    The direction vectors of r1 and r2 at P(2,1,3) will be the derivatives of r1 and r2 at t=0 and u=1 respectively. So, dr1/dt = 3,-2t,2t-4 = (3,0,-4) , and dr2/du = 2u,6u^2,2 = (2,6,2) .
    The cross product of (3,0,-4) and (2,6,2) is (24,-14,18), which reduces to a direction vector of (12,-7,9) which is perpendicular to (3,0,-4) and (2,6,2) at P(2,1,3) .
    So a plane perpendicular to the direction (12,-7,9) , and passing through P(2,1,3) is the dot product of (12,-7,9) and (x-2,y-1,z-3) = 0 , which is 12x-24 -7y+7+9z-27 =0 ====> 12x -7y + 9z = 44 .
    Ratch
