Talking between CMOS and TTL.
Discussion in 'General Electronics Chat' started by hp1729, Feb 2, 2016.
  1. hp1729
    Nov 23, 2015
    2,081
    231
    Communicating between CMOS and TTL can be a small problem, especially when there is a voltage difference. Attached are a few examples. Does anybody have ideas to add? Maybe something on interfacing to 3.3 V or lower systems? I haven't spent much time with newer things yet.
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,375
    651
    In general, you need to consider input thresholds/loading and output swing and drive current. You also need to make sure CMOS input or output diodes don't conduct sufficient current to cause latch up and/or electromigration.
  3. Bordodynov
    May 20, 2015
    670
    194
    See:
  4. hp1729
    Nov 23, 2015
    2,081
    231
    Good words, of course.
  5. ScottWang
    Aug 23, 2012
    4,924
    777
    The R1 of circuit of the right top should be change to 330Ω, otherwise it can't say it used for any TTL, it only can be used with 74LSxx, because the low level input voltage will be too high.
    Do you mean TTL interfacing to 3.3V CMOS or lower voltage and 3.3V CMOS or lower voltage interfacing to TTL?
  6. nwvlab
    Feb 3, 2016
    Hi there!
    There are a lot of ways to interface TTL and CMOS or CMOS and CMOS with different voltages. It depends on your speed, cost, area and power consuption requirements.
    Here are some (except those you already mentioned):
    Connecting a 3-3V CMOS ouput to TTL input:
    If your CMOS can sink/source enough current, it should be fine, direct connection (beware of possible latch-up problems, as the TTL input is pulled high).
    Connecting a 3.3V CMOS output to 5-V CMOS input or connecting a TTL output to 5-V CMOS input:
    1) Use an HCT for the input.
    2) Use a level translator IC between the two gates.
    3) Use a BTJ/MOSFET with the base/gate connected to 3.3V (through a resistor if using BJT), the emitter/source connected to the CMOS output, and the collector/drain (pulled-up @ 5V, through a resistor) to the 5-V CMOS input.
    4) If you can accept an inverted signal, use a BJT/MOSFET with emitter/source to ground, base/gate connected to the input (with a resistor if using BJT) and collector/collector pulled high @5V.
    Connecting a 5V CMOS to 3.3V CMOS
    1) Use a resistor divider.
    2) Use a diode (better if schottky), with cathode toward the input, and a pull-up resistor.
    3) Use a level translator IC.
    cheers!
  7. Bordodynov
    May 20, 2015
    670
    194
    See:
  8. hp1729
    Nov 23, 2015
    2,081
    231
  9. Bordodynov
    May 20, 2015
    670
    194
    No.
    I used a transistor with a protective zener diode (Vz ~ 9V).
    VDSS, VCC Drain-Source Voltage, Power Supply Voltage 25V.
  10. hp1729
    Nov 23, 2015
    2,081
    231
    Works good, thanks.
