Not necessarily true. Read this thread. Combined resistors of 0.1% tolerance can give up to 0.2% error worst case!I don't see the need for two 0.5% resistors to get a 1% tolerance combination. Combining resistors of a given tolerance in series or parallel gives a result of the same tolerance worst-case. In fact, the statistical distribution of the combined result tends to be tighter, as to obtain a worst-case result requires two devices to be at their tolerance limit.
Up in value, but down in wattage rating.An older technician I knew told me that they used to file away part of the element on large carbon composition resistors to adjust them up in value.
Yes, but that is precisely the division ratio error issue that I referred to in the second part of my post. You can indeed get a divider ratio error percentage approaching the sum of the two resistance tolerance percentage errors, but that is not the same situation as building a single composite resistance.Not necessarily true. Read this thread. Combined resistors of 0.1% tolerance can give up to 0.2% error worst case!
From the land of thick film hybrids when designing resistors, which are trimmed to value by cutting into them there is no factor for the kerf.Up in value, but down in wattage rating.
Pat - W9ZO
by Jake Hertz
by Aaron Carman
by Duane Benson
by Jeff Child
