Tachomter PIC18F2550 Help !
Discussion in 'The Projects Forum' started by splendid-electron, Jan 26, 2014.
  1. splendid-electron
    Jan 26, 2014
    14
    I need your help to understand more how does this circuit work theory !
  2. ericgibbs
    Jan 29, 2010
    2,599
    394
    It could be either 'reflective' or 'interrupted' ,, Emitter to Detector.
    Do you have a link or other information on where it is used.?
    E
    splendid-electron likes this.
  3. splendid-electron
    Jan 26, 2014
    14
  4. ericgibbs
    Jan 29, 2010
    2,599
    394
    hi,
    Its as the link states, the Emitter IR LED is ON for 1second and the IR Detector receives an increase in reflected IR every time the White piece of paper passes under the faces if the Emitter and Detector.
    The transistor at the detector is used to amplify the weak reflected IR pulse voltage to level suitable for the MCU to 'see' as a pulse.
    Is this what you are asking.?
    E
  5. splendid-electron
    Jan 26, 2014
    14
    yes.. but i didn't how can i find the value of the resistors ??
  6. ericgibbs
    Jan 29, 2010
    2,599
    394
    hi,
    The values of the resistors are already shown on the circuit you posted.
    example:
    4.7K ohms and 68 Ohms
    1.8K, 1K and 10K Ohms
    The unmarked Diode 'D' is a general purpose signal diode.
  7. splendid-electron
    Jan 26, 2014
    14
    hi eric please can u give a tutoriel how to programm with mikroc whats is the instructions i should follow
    im beginner
  8. ericgibbs
    Jan 29, 2010
    2,599
    394
