tachometer using LM2917
Discussion in 'The Projects Forum' started by keimic, Sep 29, 2010.
  1. keimic
    Sep 29, 2010
    Hello....I am new to this forum and I am interested in building a tachometer also using the LM2917. I have tried the Voltage Driven Meter Indicating Engine RPM circuit that there is on the IC's datasheet. The only variation I am doing is that I am applying it to a 4 cylinder engine. But when I tested it the voltage did not vary that much...from 2.7V to 1.8V even though I varied the revs from idling to 4000 RPM.
    Any Help?
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  4. keimic
    Sep 29, 2010
    Hello thanks for your reply. I am sorry I didn't reply very soon. Just to tell you that I solved the problem. It seemed that I had a ground missing on one of the pins. Then I connected the circuit as it should be and everything worked properly. 10x very much for the help and I'm sorry with the threads issue but I am new to this forum.
