tachometer sensor type
Discussion in 'The Projects Forum' started by Swashia, Dec 24, 2012.
  1. Swashia
    Nov 24, 2012
    Hi
    I am currently building a tachometer for wind turbine shaft. My question is what kind of sensor type should I use? Hall effect or IR (reflective object sensor)? Which one is more weather proof ? which one is easier to implement?
  2. tshuck
    Oct 18, 2012
    3,531
    675
    Hall effect sensors are generally more robust... IR sensors require line-of-sight and run into problems when things get dusty/muddy/rainy/snowy.
    As far as ease to implement, they are about the same, unless you are referring to an IR sensor like those Sharp IR distance finders, then Hall effect sensors would be much easier...
  3. Dodgydave
    Jun 22, 2012
    5,141
    767
    Can you not monitor the AC frequency of the output voltage?
