tachometer output on car ECU
Discussion in 'General Electronics Chat' started by francisg3, Jan 6, 2012.
Thread Status:
Not open for further replies.
  1. francisg3
    Mar 8, 2009
    10
    I have a PE ECU installed on a motorcycle engine (Honda CBR600F4I) and the tach output states that a 12V square wave is outputted with a 30% 'on' and 70% 'off' duty cycle with 2 pulses/crank revolution. I understand that this means that the voltage read from a volt meter would be 3/10 of the actual output correct?
    I guess I am just trying to get a better idea of what the 30% 'on' duty cycle really means to the values being outputted from the ECU. I plan on using an LM2907/LM2917 circuit to output the RPM to an ADC port on an ATMEGA8 chip using its ADC.
    I don't have the exact frequency range that the ECU outputs so I am not 100% sure about the LM2907/LM2917 would look like. Do I really need these frequencies in order to build the circuit. I have models from LTSpice simulating similar circuits but I need to be more sure on the whole 'duty cycle' business.
    Any input would be greatly appreciated!
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    I doubt that this thread will survive; it likely conflicts with the site's rules regarding automotive modifications.
  3. francisg3
    Mar 8, 2009
    10
    This is for a school project...
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    I am going to lock this thread for the moment while the moderators consult over whether it violates our rules against automotive modifications.
    hgmjr
Thread Status:
