Tach generator to PLC
Discussion in 'General Electronics Chat' started by carbonel28, Apr 5, 2009.
  1. carbonel28
    Apr 5, 2009
    I have a tachometer generator that is used to monitor RPM of a motor. The receiving units reads the frequency to display the RPM. 0-100% is 0 - 70.2 Hz. I need to convert this signal to a pulse to read in a PLC. I will count the pulses and convert to RPM. It would be best to have the output be a switch so I can use the power from the PLC to pass through the switch on an input card.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    What are the tachometer's specifications?
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What is the output signal from this tach generator? Sine wave, square wave?
    What voltage
  4. carbonel28
    Apr 5, 2009
    Sorry........a little new at this.
    It is a tach generator from a gas turbine. It produces a sin wave 0-7 VAC.
    I would like to take it from sine wave to square wave and have it operate a switch so I can connect it to a PLC input card and count the pulse to calculte RPM. I would like to have the PLC source the power to the normally open switch and feed it to the input channel of the PLC.
