Tables
Discussion in 'Feedback and Suggestions' started by studiot, Apr 12, 2009.
  1. studiot
    Thread Starter AAC Fanatic!
    Nov 9, 2007
    5,005
    515
    On quite a few occasions, the last one being yesterday, I have wanted to lay out a table, in a reply in a thread.
    I notice that, in a different thread, at least one other poster also wanted to do this yesterday alone.
    All the ways I have found of doing this have been cumbersome, clumsy and unseemly.
    So I would place high priority on the goal of introducing a simple table function.
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    That is a really good suggestion; tables are something that I would imagine would be widely used. I will mention this to Rob to see what we can do. Thanks.
    Dave
  3. b.shahvir
    Jan 6, 2009
    444
    At the outset, could you guys also provide a provision to edit and upload attachments on Private Messages too?....if it's technically possible! :)
    Thanx
  4. jrap
    Administrator
    Jun 25, 2006
    967
    202
    Hi studiot, many thanks for the suggestion.
    I have installed a Table add-on which looks like it will be perfect for the board.
    Usage information can be found at http://forum.allaboutcircuits.com/misc.php?do=bbcode
    Generally, the [ table ] tag is used as follows:
    Which will produce
    head col1 head col2 head col3
    row1 col1 row1 col2 row1 col3
    row2 col1 row2 col2 row2 col3
    Cheers!
    Rob
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Cheers, Rob.
    Looks spot on. Will have a play around with that later.
    Dave
  6. studiot
    Nov 9, 2007
    5,005
    515
    This is really good, but I copied and pasted your ?code? and this is what I got.
    [ table="head"]head col1|head col2|head col3
    row1 col1|row1 col2|row1 col3
    row2 col1|row2 col2|row2 col3[ /table]
    So what is stupid old me doing wrong please?
  7. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Rob has padded the [ table="head"] and [ /table] tags with trailing blank-spaces within the []s to prevent the board rendering the table. Remove those two spaces and it will give you your table, i.e. [ table="head"] becomes
    , etc.
    Dave
  8. studiot
    Nov 9, 2007
    5,005
    515
    jesting testing resting
    Ω θ row1 √
    Ʃ :D
  9. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Can even embed emoticons! We're in for some fun in the future, aren't we :D
    Dave
