Table saw motor problems
Discussion in 'General Electronics Chat' started by LCLARKE, Feb 6, 2010.
  1. LCLARKE
    Feb 6, 2010
    Hi, i was wondering if any of you guys can help. I have a table saw that runs off 220v. Ive been using it for about a week, when i went to turn it on and all i got was a sound like it wanted to go, but wasn't. I checked the cap and it was blown open, so i changed that and its still the same. Any advice would be very helpful,
    L Clarke.
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    First guess would be that the start switch is fouled with sawdust and not making contact. Of course this assumes the motor is free to turn and not locked up.
  3. retched
    Dec 5, 2009
    5,201
    313
    Did you replace the cap with the same spec as the one that was dead?
    Did you make sure that was the correct cap for that motor?
    If Yes to #2, (and the motor still spins freely) Your start windings may be bad.
  4. mik3
    Feb 4, 2008
    4,846
    63
    Have you considered a faulty bearing?
  5. Mike33
    Feb 4, 2005
    349
    25
    Can you blow it all out w/compressed air, and take some resistance readings across the coils? Can the shaft be turned easily by hand? Seems like either something (a coil) is burned out, or is mechanically being prevented from moving (bound w/sawdust etc). Might need to replace the start cap again, too, if it blew...
  6. PackratKing
    Jul 13, 2008
    850
    216
    Sawdust in the switch is the most common malady.
    Capacitor blowouts or burnt start windings are the result of inability to start, when the motor just sits and grunts, also causing the thermal overload to trip. Thermals degrade rapidly if tripped too many times.
    Good idea to fieldstrip the motor and clean it out, change bearings if necessary. 'elluva lot less expensive than a new motor.
