Table fan motor for electric bike..??
Discussion in 'General Electronics Chat' started by utilityhacker, May 31, 2014.
  1. utilityhacker
    May 1, 2014
    40
    so I have a tablefan that i dont use any more.
    but the motor is still pretty good.
    i want to know if i can use this for making an electric bike.
    its like i can put a gear on the motor then put a chain across the motor and the rear wheel.
    the fan works directly on power outlet (230v,60Mhz).
    i have these rechargeable lead acid batteries (4 of them).
    will they be able to run the motor??
    suggestions are appreciated.....
    thank you
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    No. Household fan motors are designed for low-current/low-torque applications.
    You would be better off to try using a 12VDC automotive starter motor.
  3. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    How long is your extension cord? :p
    Max.
  4. utilityhacker
    May 1, 2014
    40
    thanks
    that was really helpful MrChips
  5. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    If using a starter (series) motor, make sure it is under load at all times.
    Max.
  6. Metalmann
    Dec 8, 2012
    700
    223
    Is the inside of the motor, as filthy as the outside?
    Clean that old girl up!
