T flip flop
Discussion in 'General Electronics Chat' started by usmanali45, Jul 16, 2010.
  1. usmanali45
    Mar 3, 2010
    12
    I want to make 6 bit counter using t flip flop, but i con't find the ic number of t flip flop. dose i use d flip flop and inverter to form t flip flop.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    I think you are referring to a toggle flip flop, the input to these flip flops are usually labeled CLK. Most flip flop chips have it. Be sure to ground the unused inputs of any chip you want to try out this way.
    Most simple flip flop chips are two flip flops in one package. You can also get packages prewired as a 4 bit counter (aka mod4). I wouldn't doubt that there are bigger, though I haven't looked in a long time.
  3. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    A T-flip-flop is a deriviate of the JK-flip-flop.
    See this page for the explanation:
    flip-flops
    Bertus
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    As far as I can tell the clock input is a standard feature. While not universal it is pretty close.
    The 4027 is pretty typical as is the 7474.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Just to be picky, a 7474 is a D flip flop, but will toggle if you tie the Q^ output to the D input.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    So it is. I was thinking of the 7472.
    You might be able to find a chip that does exactly what you want in one part.
    • 7472.pdf
      File size:
      124.5 KB
      34
