T flip flop circuit, MMExer5.8
Discussion in 'Homework Help' started by PG1995, Jan 17, 2012.
  1. PG1995
    Thread Starter Active Member
    Apr 15, 2011
    753
    5
    Hi
    Please have a look on the attachment. Please help me with the query there. Thanks a lot.
    Regards
    PG
  2. Zazoo
    Member
    Jul 27, 2011
    114
    43
    It's still a counter, it just doesn't cover the full-count. If the device ends up in state 11 (by a glitch) then it just resets.
  3. PG1995
    Apr 15, 2011
    753
    5
    Thank you.
    Okay. That means full count could be from 00, 01, 10, 11, but it doesn't cover the last value. By the way, what kind of glitch that could be?
    Best regards
    PG
  4. Zazoo
    Member
    Jul 27, 2011
    114
    43
    ESD is one way that a circuit could end up in an invalid/unused state. Typically you want these unused states to simply transition back to reset (00).
  5. PG1995
    Apr 15, 2011
    753
    5
    Thank you for the information.
    Best regards
    PG
  6. PG1995
    Apr 15, 2011
    753
    5
    Hi
    Please have a look on the attachment. Please check if the part (a) is correct, and please answer the questions related to part (b) so that I can proceed to implement the function. Here is the scan from the solution manual (to someone who doesn't know, it has been found that mostly solution manual gives wrong solution). Thank you very much.
    Regards
    PG
  7. Georacer
    Nov 25, 2009
    5,151
    1,266
    Part a is correct.
    Your assessments are correct. When we use the summing symbol Σ, we refer to the SoP form, whereas the multiplication symbol Π, refers to the PoS form.
  8. PG1995
    Apr 15, 2011
    753
    5
    I'm sorry to ask this again. So, is it really so, F'(A,B,C,D)=Ʃ(3,8,12,15), for the the function F in the attachment. Thanks.
    Best regards
    PG
  9. Georacer
    Nov 25, 2009
    5,151
    1,266
    Yes, F'=Σ(3,8,12,15), for part b.
    PG1995 likes this.
