T-03 RF remote control
Discussion in 'General Electronics Chat' started by stephanj, Jun 20, 2014.
  1. stephanj
    Jun 20, 2014
    Hi, I want to extend the range on the 4 channel 433.92Mhz RF remote control.
    I have read that you could extend or solder a small antenna to it but I can't find where the antenna on the circuit board is.
    The remote is for Watts Clever Power Socket. Could someone tell me if I am on the right track? How/ where would I look for the internal antenna on the remote. I attach photos of external and internal parts.
    Stephan
  2. Brevor
    Apr 9, 2011
    282
    56
    The antenna can be seen in the photo that shows the bottom of the PC board. It is the loop of copper that runs around the led.
    stephanj likes this.
  3. Papabravo
    Feb 24, 2006
    10,338
    1,850
    What makes you think that you know how to do this correctly?
    Do you have any measurement equipment that will let you verify the result?
  4. wmodavis
    Oct 23, 2010
    737
    150
    He can use a tape measure to measure the transmission distance before and after.
    Papabravo likes this.
  5. Papabravo
    Feb 24, 2006
    10,338
    1,850
    He's as likely to reduce the range as increase it if that's all he has.
  6. wmodavis
    Oct 23, 2010
    737
    150
    Yeah but he can measure his success or lack thereof in inches, feet, yards or millimeters.
  7. Papabravo
    Feb 24, 2006
    10,338
    1,850
  8. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Increase the battery voltage. :)
