I recently attempted a build of the Notes and Volts NaV-1 synth (Board layout and schematic available at http://www.notesandvolts.com/2013/03/nav-1-arduino-synth-build-it.html) and I *think* the ATMEGA328PU that drives it is not wanting to start up.
Upon completion of the board, I triple-checked that all trace cuts were done in the appropriate locations and that my multimeter did not show continuity across them. I verified that all the ground points had continuity, then powered up the board without any chips in the sockets, and verified that all the places that should be getting 5v were getting 5v. I plugged all the chips in, powered the board back up, and found that I was unable to upload the firmware to the ATMEGA using the ISP headers, so I removed the chip and stuck it in the chassis of an UNO to upload the firmware, then popped it out and put it back in the synth mainboard. After that, I powered up the synth, and the LCD turns on, with two rows of boxes, but no splash screen, and there's a repetitive noise coming out of the audio out connection. So, I hooked up the oscilloscope, and probed the pins of both microcontrollers where signals should be coming out, but only got ~2mV noise.
Here's a video of it failing to start:
This is BY FAR the most complicated thing I've ever built, so I'm really beyond my skill level here... I don't know what to check next. I have triple checked that all the components, jumper wires, and trace cuts are correctly located, that the upload was successful to the ATMEGA chip... there is a pin that's slightly bent on the optocoupler, but as far as I can tell it's still working, and even if it wasn't it shouldn't affect the rest of the board.
How should I proceed in diagnosing this so I can get it fixed?
Thanks.
Thanks.
