Syncing thumb drive
Discussion in 'Computing and Networks' started by Wendy, Sep 3, 2014.
  1. Wendy
    Thread Starter Moderator
    Mar 24, 2008
    20,772
    2,540
    OK, this is probably a dumb question, but I need to know how.
    I have a 8 gig thumb drive I keep my working files, both 3D printer stuff and PaintCAD, as backups and transport. I would like to keep the files current with my HD. Are there simple commands in Win7 to do this? I suspect there are.
    I don't want to rewrite my entire file set every time, I would like to make this thumb drive last.
  2. Markd77
    Sep 7, 2009
    2,803
    594
  3. joeyd999
    Jun 6, 2011
    2,757
    2,929
    Consider Git.
  4. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Consider using XCOPY in a CMD window. Type XCOPY /? in a DOS command window to get a list of switches like overwrite only newer files,only files that exist etc. When you are happy, put the commands in a .BAT file and put a shortcut to that on the desktop.
    Its crude, I'll admit, and your backup will not delete files that no longer exist in the source directory but you get real copies of your files that are not compressed with some proprietary (gone next year) format.
    That said, I've been very impressed with Acronis True Image and Backup that I use on the laptops.
    I wouldn't worry about the life of the thumb drive. You should back up to multiple physical drives anyway.
  5. Brownout
    Jan 10, 2012
    2,375
    998
  6. tom_s
    Member
    Jun 27, 2014
    287
    342
    not a dumb question :)
    rather than copy, you'd like to sync the files? mem stick to hdd and vice versa?
    i'm working on the assumption, you take the work home, play there, update and take back to work.
    edit: i'm not partial to ms products though synctoy may do exactly what you want, personally i use cobian backup http://www.cobiansoft.com/index.htm
  7. sirch2
    Jan 21, 2013
    1,008
    351
    Personally I use XCOPY as suggested above. Write a little batch file that does a 2-way copy of newer files, which can be done with the /d switch So the batch file xcopy's newer files from the thumb drive to the HDD and then xcopy's newer files from the HDD to the thumb drive. One nice feature of XCOPY is that you can provide it with a list of files and folders to exclude so if temporary files and the like you can exclude them and speed up the copy.
  8. BMorse
    Sep 26, 2009
    2,675
    234
    SyncToy would be your best bet, SyncToy provides a fairly user-friendly interface to navigate, and should pose no difficulty to anyone familiar with Windows. and it works with XP, Vista and 7.
  9. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    I tried SyncToy, I'll probably stick with it. It does have one minor problem, once it is logged into a thumb drive it doesn't want to let go! I have to pull the thumbdrive off while it is active, as the disconnect feature in windows doesn't work anymore.
    Thanks for the input everyone, it was helpful.
    BMorse likes this.
