Syncing the ICL7660
Discussion in 'General Electronics Chat' started by Stryker, Mar 30, 2009.
  1. Stryker
    Mar 26, 2009
    7
    How can be synced an ICL7660 operating between gnd and +10V by a clock swinging between gnd and +5V ?
    How much should be the minimum amplitude of the clock applying to the OSC input? Swinging from where to where?
    I'm confused!:confused: Please clarify!
    Thanks in advance
    Stryker.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Stryker
    Mar 26, 2009
    7
    The datasheet doesn't have enough explanation... Just says a rail to rail clock... it's not in detail.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    See page 6, 1st paragraph, 2nd sentence.
    Instead of a TTL IC, you could use a simple NPN transistor with a 3k base resistor and a 10k resistor from the collector to Vcc (+10v). Feed your existing clock to the other side of the 3k resistor.
